It is currently Sun Mar 01, 2015 1:26 pm
 Post subject: My first gaming PC
PostPosted: Sat Mar 15, 2014 12:12 am
These are the specs of the pc i built on magicmicro.com trying to figure out if its a good starter gaming PC i have bout $1000 to play with
AMD FX-4300 Piledriver (Vishera) 3.8GHz (Quad Core) 32nm, AM3+ 8MB Cache
Spire Kestrel-King II AMD 64 fan
GIGABYTE GA-78LMT-USB3 AM3+, Onboard video,HDMI, USB3.0
8GB (2x4GB) PC17000 DDR3 2133 Dual Channel (high performance memory)
GeForce GTX 650 1GB PCI EXpress 16X Dual head, HDMI
1TB Western Digital Green SATA3 6GB/s 64m cache
Hard Drive Cooling Fan Aluminum Internal
LG 22x DVD Recorder Dual Layer +R/RW -R/RW
Realtek HD digital audio (onboard)
Ethernet network adapter (onboard)
Apevia Sniper 2 Black and Green, front USB 3.0
Apevia 700W Extra Quiet Power Supply SLI & X-fire ready
Microsoft Windows 8.1 64-Bit DVD
This is another PC prebuilt on tigerdirect.com both fall in price range just trying to figure out which to choose as a starter follow the link
http://www.tigerdirect.com/applications ... C447-G1318
Any comments will help or if u know where i could get a better deal for my money let me know
 Post subject: Re: My first gaming PC
PostPosted: Sat Mar 15, 2014 8:09 pm
Just eyeballing your components, I can't see how you're even close to $1000 - I'd guess you're closer to $600. Please post the cost of the components and let us know you're actual budget. If you have $1000, spend $1000.
Try using pcpartpicker.com. Here's an example of a build close to $1000. If I missed something, you can adjust the GPU down to help fit in the component.
CPU: AMD FX-6350 3.9GHz 6-Core Processor ($139.99 @ Newegg)
CPU Cooler: Arctic Cooling ACALP64 Pro 36.7 CFM CPU Cooler ($14.99 @ Newegg)
Motherboard: ASRock 970 EXTREME4 ATX AM3+ Motherboard ($99.49 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($79.99 @ Newegg)
Storage: Seagate 1TB 2.5" 5400RPM Hybrid Internal Hard Drive ($99.99 @ Newegg)
Video Card: Asus GeForce GTX 770 2GB Video Card ($365.91 @ Newegg)
Case: Antec Three Hundred Two ATX Mid Tower Case ($70.98 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($14.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($101.98 @ Newegg)
Total: $1038.30
(Generated by PCPartPicker 2014-03-16 00:05 EDT-0400)
Hope this helps.
PostPosted: Sun Mar 16, 2014 10:29 am
I have the Antec 302 case. While it is nice and roomy, it's side panels are flimsy in that they have some flex. But it's not really a big deal. It just sits there. It's got two huge fans (120mm and 140mm), two 2.5mm areas for ssd mounting, enough hdd bays, and good cable routing from behind. My case is very tidy inside.
And the size...I thought bigger was better. But in my opinion, I would have bought a smaller case. People who have huge cases like cosmos II, wow :o Just my opinion, that's all.
PostPosted: Sun Mar 16, 2014 10:53 am
http://www.logicalincrements.com/
I'm just going to drop this here because I don't feel like putting together a PC Part Picker list.
