It is currently Wed Apr 01, 2015 12:39 am
 Post subject: First Build: Need help on what type of RAM
PostPosted: Fri Mar 14, 2014 2:51 pm
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor
Motherboard: ASRock H87 Pro4 ATX LGA1150 Motherboard
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Asus GeForce GTX 770 2GB Video Card
Case: Cooler Master HAF 912 ATX Mid Tower Case
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)
This is what i have so far, i just need to pick what type of memory. Im using this for gaming and browsing and maybe use multiple monitors. What do you think of the build? and what type of memory should i pick? (brand? 8 or 16 gb?)
 Post subject: Re: First Build: Need help on what type of RAM
PostPosted: Fri Mar 14, 2014 7:30 pm
I usually stick with Corsair or Crucial. But G.Skill is getting lot of good marks. As far as the other specs, stick with 8GB and DDR3-1600 at the most.
PostPosted: Sun Mar 16, 2014 1:44 pm
Do you have any specific one you would recommend that is compatible with the motherboard?
PostPosted: Sun Mar 16, 2014 1:50 pm
As long as it meets the RAM type and speed, it should be fine. The memory compatibility list is just whatever the manufacturer tested and can guarantee will work. It's not a list of what only works.
