It is currently Sun Mar 29, 2015 12:03 am
 Post subject: HD 7850 Crapped itself? Possibly looking for budget replacem
PostPosted: Sun Feb 23, 2014 1:59 pm
Okay.. I guess I had my HD 7850 (2gb) for a good year or two, and within that year or two, I may have been "mining" bitcoins on it 24/7 while doing other things as well (games mostly only thing noteworthy). I'm not quite sure how I noticed problems to begin with, but I suppose it dosen't matter. I realised my fans on the card were dieing, going very slowly, and my card started to suffer. One morning I woke up seeing my GPU at a constant temp of 102 (my computer was mining bitcoins at the time, so, under extreme load), and I shit my pants. I took the card out of the computer, unscrewed the fans from the heatsink, and tried to clean them and whatnot. Didn't do anything. I did this afew times, before I said screw it (at this point I was desperate, didnt care), and doused those fans with WD40. All seemed ALRIGHT, fans were going at a better speed. I figured it was only a temporary solution, so I bought a replacement fan thingy that mounts on heatsink.
I get the feeling the damage was already done, because now when I play games(usually) or put alot of stress on my computer(actually its usually only when I play games), my video card dosent "crash" in the general sense of the word, it makes my monitors go haywire, like crazy artifacts everywhere (in the same way a tv channel goes kaput and shows snow)(when this happeneds my tempature is fine, seeing as I got a new fans), and I have to reboot. I assume, no doubt, my video card is the culprit, and needs to be replaced?
If that is so, and I assume it is... I guess I'm on the market to downgrade my videocard to 1gb (budget), and im looking for some suggestions! I do indeed want to stick to AMD(ATI) because they are king of "mining" bitcoins(or other altcoins), compared to nvidia. My only requirements is that it needs to have 2 monitor plugs(one HDMI & one DVI) as I use two monitors, PCI-E, and hopefully 1gb. If I had to put a number on my total possible cost, I suppose I'll go with $150. I'm just looking for a good bang for my buck!
I was considering this one here: http://www.amazon.com/gp/product/B00A0H ... ey8chud-20
As well as this one here: http://www.newegg.com/Product/Product.a ... 6814129189 This one seems too good to be true? 1gb $45?
I'm not too knowledgeable on these things, so I'd appreciate any and all insight!
THANKS!
