It is currently Fri Mar 27, 2015 8:51 pm
 Post subject: building pc
PostPosted: Tue Feb 11, 2014 9:51 am
i went for R9 290 , G990FXA-UD3 , 8 Gb G-Skill RAM , 850 bronze seasonic , 8350 AMD , many guys told me these staff are good , but the thing is you can buy good components but they dont get you the performance you want , while you can lower quality components for which get you a same or slightly higher performance than the more higher editions because the lower ones work in harmony & much better compatibility mode , i am confused , i have no idea on which basis i choose my components to reach that goal , so please tell me if the components i mentioned above are the right match for each other or if they have compatibility issues or if there are replacements for any these components to boost up my total performance , regarding that i stick to the R9 290 , i wont change it , so replacements are considered for the rest of components regardless of their budget changes , it would be helpful if you mentioned nominees ( if there are ) as much as possible cause there aint much of variety in my country ,for any one who would suggest Intel core instead of AMD plz tell me why ??
