It is currently Mon Jan 26, 2015 12:37 pm
 Post subject: Best upgrade path?
PostPosted: Fri Feb 07, 2014 3:55 am
Hello again, I'm hoping someone can provide some insight. I am attempting to find out what GPU or GPU's would provide the best experience gaming at 2560x1600. I am not opposed to crossfire or SLI if needed. The few benchmarks I've been able to find (I am at work and a lot of the sites are blocked) seem to indicate that GTX770's in SLI would work well, but that's a $800 investment minimum. Would there be a less expensive alternative?
Thanks in advance.
 Post subject: Re: Best upgrade path?
PostPosted: Fri Feb 07, 2014 7:53 am
It depends on what games you're playing and how much do you care about fastest FPS possible. I have a 2560x1440 monitor and get by with a single GTX 670 just fine.
PostPosted: Fri Feb 07, 2014 8:16 am
I'm looking to the games that are being released over the next year or so. Witcher 3, Elder Scrolls Online, maybe a few others. I am pretty picky about FPS not dropping below 30FPS.
PostPosted: Fri Feb 07, 2014 9:45 am
I'd wait a while, the GeForce 800 series is supposed to be due this year.
PostPosted: Fri Feb 07, 2014 9:53 am
Good point. I guess I'm in no huge rush.
PostPosted: Fri Feb 07, 2014 9:55 am
Ok, I have a follow-up question then. What would you recomend for gaming at 1080?
PostPosted: Fri Feb 07, 2014 9:57 am
GTX 760 if you're penny pinching.
PostPosted: Fri Feb 07, 2014 10:00 am
Great. That's exactly the direction I was leaning.
PostPosted: Fri Feb 07, 2014 10:05 am
If this is a short term thing, I'd recommend something in the $150 range. Those will play most games made last year and before at 1080p on high/max settings above 30FPS.
PostPosted: Sat Feb 08, 2014 3:32 am
Dang, you must be psychic. It is a short term build. I'm going to use it while my main machine is being shipped (45-60 day process), with the intention of selling it afterword’s. I had planned to put a new, high end GPU in it and swap them when my main computer arrives, but I think you've swayed me into waiting on the next-gen 800 series to make an upgrade.
