It is currently Sun Mar 29, 2015 6:42 pm
 Post subject: A bit of an upgrade, mostly new parts.
PostPosted: Sun Feb 02, 2014 10:35 am
So, here is my list of items that I have ordered and have not received or put together yet.
I already have the chassis and the motherboard, the other parts, ordered just the other day.
1 x Cooler Master Cosmos II - Ultra Tower Computer Case with Metal Body and Hinged Side Panels
http://www.newegg.com/Product/Product.a ... 6811119252
1 x ASRock 990FX Extreme9 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.a ... 6813157358
1 x AMD FX-9590 Vishera 4.7GHz Socket AM3+ 220W Eight-Core Desktop Processor - Black Edition FD9590FHHKWOF
http://www.newegg.com/Product/Product.a ... 6819113347
5 x Cooler Master JetFlo 120 - POM Bearing 120mm Red LED High Performance Silent Fan for Computer Cases, CPU Coolers, ...
http://www.newegg.com/Product/Product.a ... 6835103190
1 x bgears b-PWM 140 Red 140mm Red LED PWM technology mini 4 pin 4 wire 2 ball bearing high speed high performance 15 ...
http://www.newegg.com/Product/Product.a ... 6835132030
1 x 200mm LED Fan on/off for Cosmos II & Stryker / Trooper
http://www.cmstore-usa.com/200mm-led-fa ... packaging/
Cooler Master Nepton 280L - PC CPU Liquid Water Cooling System, All-In-One Kit with 280mm Radiator and 2 JetFlo Fans
http://www.amazon.com/gp/product/B00HEYRS5K/
Enermax Platimax 1350W 89+ EPS 12V Modular PSU 240-Pin 1600 Power Supply, EPM1350EWT
http://www.amazon.com/gp/product/B008PSEMTY/
Corsair Dominator Platinum 32GB (4x8GB) DDR3 2400 MHz (PC3-19200) Desktop Memory CMD32GX3M4A2400C10
http://www.amazon.com/gp/product/B00A6JFWNA/
ASUS Computer International Direct Blu-Ray Writer BW-16D1HT
http://www.amazon.com/gp/product/B00DWFPDJI/
Logitech MK710 Wireless Desktop Mouse and Keyboard Combo
http://www.amazon.com/gp/product/B0036E8V08/
Arctic Silver 5 Thermal Compound 12grams with ArctiClean 120ml Kit (Includes 2 30ml ArctiClean 1 and 2 30ml ArctiClean 2) with Bonus DB Roth Microfibe
http://www.amazon.com/gp/product/B001RUEKNA/
Plus, I may be interested in getting some new BitFenix Alchemy Multisleeved Cables,
or some of BitFenix Alchemy Multisleeved Extension Cables as I may need for my PC.
http://www.bitfenix.com/global/en/produ ... emy-cables
http://www.amazon.com/s/ref=nb_sb_noss? ... +extension
That is because the cables on that Enermax Platimax 1350 PSU might be
a little on the short side for reaching everything inside a very big PC case.
What I already have now, are my graphics card, and that is
a Sapphire Radeon HD 6990, a Samsung 840 EVO 1TB SSD,
and a 3TB hard disk drive, a Hitachi Ultrastar 7K3000 HDD,
HUA723030ALA640 (0F12456), 3TB 7200 RPM 64MB Cache,
SATA 6.0Gb/s 3.5" Enterprise HDD, and a Blu-ray optical drive.
Come to think of it, I probably should keep my current optical drive,
so that I will have two optical drives, this is the one I have now, here:
LITE-ON 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM 8MB Cache SATA Blu-ray Burner with 3D Playback iHBS212-08 LightScribe Support
http://www.newegg.com/Product/Product.a ... 6827106348
Will this be alright in my rig setup as shown above, or out of place?
I mean I will be getting the ASUS Blu-ray drive as listed, this will be
a second optical drive, this Lite-On won't be my only optical drive.
I'm still not sure concerning any need I may have for extension cables.
The fans as listed are for replacing many of the included fans, with either,
higher air flow (CFM) fans, most importantly, or also ones with red LED's.
Future plans to add to this for further upgrades, a dual GPU Radeon R9 card,
and possibly at some time (when available), 64 GB RAM, as 4 x 16 GB RAM,
this is supported by my motherboard, but good luck trying to find any yet. NOT!
Any useful or helpful feedback or input concerning my choice and combination of items is welcome, thank you.
 Post subject: Re: A bit of an upgrade, mostly new parts.
PostPosted: Tue Feb 18, 2014 9:32 pm
I already put together this build before now.
Please, no reply is necessary at this point.
