It is currently Sat Feb 28, 2015 11:35 pm
 Post subject: How good is the AMD FX 8350 cpu for 3d work?
PostPosted: Sun Jan 26, 2014 8:24 am
Hello everyone,
Am currently looking at buying a desktop to support my modelling and animation works. Also should be capable for handling rendering of the 3d content. I may use the pc for light gaming but more so for my 3d works.
My specs are as follows
CPU: AMD Fx 8350 unlocked edition
Mobo: Asus Gryphon z87
GPU: Hd 7950 3gb card
Ram: 16 gb
PSU: seasonic 750watts
Do provide you views on this configuration and also if an alternative exists also how good is the AMD 8350 against i7 4770k?
 Post subject: Re: How good is the AMD FX 8350 cpu for 3d work?
PostPosted: Mon Jan 27, 2014 10:29 am
What kind of tools are you looking at? Do they have API support (OpenGL, CUDA, OpenCL, etc.)? I'm inclined to think that for modeling, more weight is placed on the GPU, and depending other things, these tools may be GPU accelerated.
