It is currently Mon Mar 02, 2015 11:38 am
 Post subject: Building My First PC
PostPosted: Wed Jan 22, 2014 12:57 pm
I've had some help before, and I feel confident in this beauty; but she needs help of a more experienced PC builder, unlike myself. I cannot find any compatible motherboards; can someone switch something up, and the build still have most of its current components?
CPU : AMD FX-8320 3.5GHz 8-Core Processor (I plan on water cooling)
Memory : Corsair Vengeance 8GB (1 x 8GB) DDR3-1866 Memory
Storage : Western Digital Caviar Black 2TB 3.5" 7200RPM Internal Hard Drive
Video Card : Gigabyte Radeon R9 280X 3GB Video Card
Sound Card : Diamond XtremeSound XS71 16-bit 96 KHz Sound Card
Wireless Network Adapter : TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter
Case : Antec Nine Hundred ATX Mid Tower Case
Power Supply : Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
Optical Drive : Lite-On iHAS124-04 DVD/CD Writer
Operating System : Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
 Post subject: Re: Building My First PC
PostPosted: Fri Jan 24, 2014 7:58 pm
First, welcome to the forums! I hope you enjoy building computers as much as I do.
There are numerous motherboards that are compatible with your CPU. It needs to be an AMD motherboard and have socket AM3+. On newegg there are 51 motherboards that have that socket. To confirm the motherboard will work with your CPU, select the motherboard and look at the specifications tab - it should say something like "CPU Type." Provided FX is one of the types listed, then you should be good to go.
If you're still not satisfied, find the manufacturer's website and search for the motherboard. You'll have to dig around (maybe check the manual) but you should be able to find a complete list of known compatible CPUs - just look for the 8320.
Hope this helps.
PostPosted: Sat Jan 25, 2014 6:58 am
Does compatibility refer to not knowing where to look or not finding a mobo to fit certain aspects of OP's feature criteria? If it is the former, then do as Latios says. Also, PCpartPicker can help out with picking a mobo. If it is the latter, then OP needs to list what mobo features are needed for us to help out.
