It is currently Wed Apr 01, 2015 8:25 pm
 Post subject: Gaming under a grand..
PostPosted: Tue Jan 21, 2014 6:37 am
I have a college who is looking to build a computer over the next few months, he'd like to build a gaming rig for on or under a grand. Someone suggested the following build for him and I'd like just like to run it by you guys to see what you think.
I'm also wondering what the build would look like with an Nvidia card instead of AMD.
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer
http://www.newegg.com/Product/Product.a ... =N82E168...
$59.99
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
$99.99
XFX FX-785A-CNFC Radeon HD 7850 Core Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
$239.99
SeaSonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
$89.99
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
$49.99
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
$239.99
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel ...
$34.99
Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
$149.99
 Post subject: Re: Gaming under a grand..
PostPosted: Tue Jan 21, 2014 7:36 am
Is it just me or do I see no motherboard?
PostPosted: Tue Jan 21, 2014 8:16 am
Maybe that's where you provide some suggestions.
PostPosted: Wed Jan 22, 2014 4:19 am
LatiosXT is correct - you are missing a motherboard. Plus, it seems that you're building a computer that's a generation older (3570 vs. the 4670). Not to mention I think $240 for a 7850 is way overpriced.
Try a website like http://pcpartpicker.com./. You can assemble a complete computer while keeping an eye on the price. It also helps with compatibility (for example, if you pick a 4670 CPU, it will show you motherboards that use the 1150 socket).
One word of advice: don't always go for the cheapest component if it means you have to buy from 4-5 different stores. You may end up spending more in shipping than you save.
Hope this helps.
