It is currently Sat Apr 18, 2015 6:27 pm
 Post subject: 2 GPUS 2 moniters
PostPosted: Mon Jan 13, 2014 8:14 pm
Sorry I have been out of the PC world for a bit b/c of life but my question is this I have two monitor and 2 gpus I currently have a GTX 560 ti powering a 24inch led screen ( 1080P ) I want to know if I could use my other card its an old one 4870 Sapphire 1g to power my older monitor a 17inch. max res on that is 1280 x 1020. Whats your thoughts ?
 Post subject: Re: 2 GPUS 2 moniters
PostPosted: Mon Jan 13, 2014 8:46 pm
Use the video card you already have in there. It supports three monitors.
PostPosted: Tue Jan 14, 2014 6:17 am
What latios said. Also, I think it is impractical to mix AMD and Nvidia gpus since you may get driver conflicts and other problems.
PostPosted: Wed Jan 15, 2014 3:14 pm
Awesome ty guys just wonder tho one monitor is set with the mini hdmi. And the older monitor is a dvi. Will it put to much load on the gpu
PostPosted: Wed Jan 15, 2014 3:48 pm
Having two monitors won't add much impact to the GPU's load. Adding a third though will cause it to not idle anymore (unless this was fixed)
PostPosted: Wed Jan 15, 2014 4:48 pm
awesome thank you Much guys really appreciate it
