It is currently Sun Apr 26, 2015 9:50 pm
 Post subject: Thermaltake 2.0 Extreme or Noctua NH-D14
PostPosted: Thu Nov 21, 2013 7:40 am
I browsed el Google all day yesterday looking at the many things on AIO "water" vs. the Noctua. I admit I was going to buy the Noctua at the end of the month, but something recently has changed my mind.
The Noctua is going for $75:
http://www.newegg.com/Product/Product.a ... =N82E168...
The Thermaltake Water 2.0 Extreme is going for $80 with a $25 rebate (or $55):
Now according to a review:
http://www.tomshardware.com/reviews/nep ... -tundra-...
Image of interest:
Spoiler: show
The Thermaltake beats the Noctua by 8*C...
The arguments I see in other places are composed of three things:
1. They whine about AIOs not being a "real" water coolers. I agree, but it can be cotton candy for all I care, as long as it cools my CPU :)
2. They say the Noctua is cheaper with same performance. Right now the Thermaltake is same price/cheaper and I don't think 8*C is same performance...
3. The Noctua is quiet. OK OK. I will give you that, but can't I slap a better pair of fans on the Thermaltake? And for pump noise I say, "You won't hear it anyway over my maniacal laugh, as I hit 5.0 Ghz with my FX-8350."
The only thing the Noctua had going for it was price and noise. Price is gone and noise is not a major factor (Because it can either be fixed or is to quiet to matter). The thought of the Noctua breaking my mobo isn't a happy thought too. ;)
Am I wrong? Which do you suggest?
P.S. Specs: CPU - FX8350; Mobo - M5A99X Evo; I want to OC that bad boy
 Post subject: Re: Thermaltake 2.0 Extreme or Noctua NH-D14
PostPosted: Fri Nov 22, 2013 4:56 pm
I've owned 2 closed-loop CPU coolers (the Corsair H50 and the Kraken x40). In both instances, the fans I received with the cooler were quiet and I cannot hear the pump once I've closed the case. In fact, I have to put my ear next to the unit to barely hear the gurgling of fluid.
I would review the Thermaltake reviews - there seemed to be several poor reviews on the first page of newegg, but I would look at tigerdirect and amazon as well. Plus keep in mind, bad reviews are posted more often than good ones.
Even with the bad reviews...Personally...I would give the thermaltake a try.
Hope this helps.
