It is currently Sun Feb 01, 2015 6:07 pm
 Post subject: which cpu/gpu combination should i use? help please
PostPosted: Fri Oct 18, 2013 7:57 pm
Here are my options (regarding what i can spend), but if you know better options i will love it :)
Cpu/gpu
- amd 8350/gtx 7970 ghz edition
- i5 4670/gtx 7950
Maybe a could affort a i5 4670 with gtx 7970 ghz edition, but it would be the last option.
I need help to get a better performance while playing games (fps and all that stuff).
Thanks for the attention and escuse my english :)
 Post subject: Re: which cpu/gpu combination should i use? help please
PostPosted: Fri Oct 18, 2013 8:14 pm
... Do you mean the Radeon HD7950/7970 GHz Edition? :D
Anyway, the second one will do better with games.
PostPosted: Fri Oct 18, 2013 8:36 pm
Hahaha i forgot to say i aint know shit of this :) thanks for the answer. Are you sure with that?
PostPosted: Fri Oct 18, 2013 9:14 pm
Yes, most places will show that Intel does do better than AMD in gaming.
Users browsing this forum: Slumpy and 10 guests
