It is currently Sun Apr 19, 2015 9:38 am
 Post subject: Upgrading Laptop Memory - Compatibility Question
PostPosted: Sun Sep 29, 2013 12:05 pm
Hey! So, I'm new to the MPC forums, so go easy on me. I've got a quick question for anyone who can help me:
I'm upgrading my laptop's memory, and I need to see if a specific type of setup will work with my specs.
What I've got is a Dell Inspirion 1764 (I know, it's terrible). Specs are as follows:
Processor - 2.26 GHz Intel Core i5
RAM - 4 GB DDR3
Hard Drive - 500 GB
Graphics Coprocessor - Intel HD Graphics
Item model number - i1764-6075OBK
Hardware Platform - PC
Operating System - Windows 7 Home Premium 64-bit
Item Weight - 6.3 pounds
Item Dimensions L x W x H - 10.87 x 16.54 x 1.31 inches
Processor Brand - Intel
Processor Count - 1
Optical Drive Type - Dual layer DVD Burner
Power Source - AC
I've looked around at upgrading the RAM because it's so ridiculously slow, and I need to run programs like Photoshop, Illustrator, and Premiere without worrying about them crashing all the time.
So, I had my eyes set on the Crucial 8GB Memory Module:
http://www.amazon.com/Crucial-PC3-10600 ... ory+module
But, then I saw that there was this Crucial 16BG Memory Module:
http://www.amazon.com/Crucial-Technolog ... ory+module
What I need to know is if I can even upgrade to the 16GB set. I'm not sure if it'll be compatible with my laptop, so if anyone can answer that question for me, it would be a massive help!
Thanks you guys!
 Post subject: Re: Upgrading Laptop Memory - Compatibility Question
PostPosted: Wed Oct 02, 2013 7:06 pm
It does not look like your computer supports 16GB: Inspiron 1764 Comprehensive specs
Personally, I'm not sure the bump to 16GB of RAM would have helped that much. You have several other components holding you back: a slow HDD and integrated graphics are probably hurting you more than the RAM. That's my guess, but maybe someone with more experience with those applications could confirm.
Hope this helps.
PostPosted: Wed Oct 02, 2013 7:29 pm
Yes, RAM is usually never a culprit unless you're legitimately running out. If anything, you'd get a bigger boost in perceived speed with an SSD replacing the HDD.
PostPosted: Thu Oct 03, 2013 11:37 am
They are correct, 8Gb is the max. supported by your laptop. With a 64-bit OS you definitely want to max out the RAM with 2 x 4Gb. This will also increase battery life due to decreases in disk accesses using virtual memory. You can also choose to use 1.35V RAM for additional battery life since I am assuming you currently have a 2 x 2Gb arrangement.
If your current drive is a 5,400RPM drive (quite possible) then an SSD would be a noticeable improvement with lower battery usage. I note it is a SATA 2 port, so a hybrid drive like the Seagate Momentus XT would give you a lot more space and pretty much all the benefits of an SSD.
Wiki
