It is currently Fri Jan 30, 2015 11:03 am
 Post subject: Legacy build needs to be checked for incompatibilities
PostPosted: Tue Sep 24, 2013 4:44 pm
*CPU-
Phenom x4 9850 (95w) or 9750 (95w)
MOTHERBOARD- in order of preference:
GA-MA770-UD3
GA-MA770-DS3P
GA-MA790X-UD4
GA-MA790X-UD4P
GA-MA790FX-DS5
GA-MA790FX-UD4P
MEMORY- Depends on board chosen, but I want the high end sort, and maximum amount...if anyone wants to recommend memory modules for the five boards above, please do!
NIC CARD- in order of preference:
DGE-528T
Intel EXPI9301CTBLK PRO/1000
Netgear GA302T
Startech ST1000BT32
*SOUND CARD-
Asus Xonar D2
*GRAPHICS CARD-
Either Geforce 6800GS or 6800GT (PCIe x16, 256 to 512MB)
SATA DVD (3Gb/s) BURNER- I'm considering Plextor PX-880SA, but welcome suggestions, just no Sony brand.
SATA HARD DISC DRIVE- SATA 3Gb/s & 750GB required. Maybe:
WD7500AVCS
WD 7500AAKS-OOBA0
SATA HDD MOBILE RACKS- Maybe:
Kingwin KF-201-DF
" KF-1000-BK
SNT-SAS136B
Vantec MRK-300ST-BK
iStarUSA T5F-SS
iRack MRA300
5.25" BAY DEVICE-
Lian Li BZ-UO1
EXTERNAL HDD DOCKING STATION- For making backups. Prefer eSATA or firewire
Orico 6618SUS-BK
Rosewill RX-DUS100
FLOPPY DRIVE- For internal floppy drive connector.
Bytecc BT-145
NEC FD1231
PCI/PCIe EXPANSION CARDS- Depends on motherboard chosen, and which chips Linux rejects, but will likely need at least eSATA and Firewire cards that work with Linux:
Syba SD-SA2PEX-2E
Startech PEX1394B3 Firewire PCIE Card
LCD MONITOR- Require 1024x768. No touchscreen.
ViewEra V151HV-
WIRED ROUTER- Require NAT & SPI;gigabit WAN. Maybe:
TP Link TL-R600VPN
Netgear FVS336G
Trendnet TWG-BRF114
Cisco Linksys RVS-4000
UPS- It must cover minimum 675W, and have quiet operation.
Cyberpower CP1350PFCLCD
APC BR1500 LCD
MEMORY CARD READER-
Plugable Technologies Plugable 2.0
SCANNER-
Canon Canoscan LIDE 30
COLOR INKJET PRINTER- Require each color to have separately replaceable ink cartridge; above average color graphics & photo print quality, & easy Linux setup. Much prefer single-function printers.
HP Officejet Pro 800 Enterprise
" " 6000 Wireless Printer
Epson WF7010
MONOCHROME LASER PRINTER- Require double sided printing (auto-duplex), use reasonably priced toner, have above average text print quality. Single-function printers much preferred.
Brother HL-2040
" HL-5370DW
Dell 2350D
" 3330DN
HP Laserjet Pro 400 M401DN
" " " " M401DNE
" " " P1606DN
Xerox Phaser 3250
If any of these components are incompatible, please let me know.
 Post subject: Re: Legacy build needs to be checked for incompatibilities
PostPosted: Sun Sep 29, 2013 3:38 pm
Welcome to the forums!
It looks like you've done your homework. At a glance, everything looks compatible. While I know some AM2+ mobos could support Phenom II CPUs, I would select one of the AM3 mobos to be on the safe side. Also, I have no Linux experience so maybe someone else could help you with compatibility with this.
I am curious: where are you getting these components? And is there a reason you're going with such old equipment?
PostPosted: Tue Oct 01, 2013 1:44 pm
I get old parts from Ebay, Amazon,+many legacy part suppliers. Old equiptments to work better with old linux kernels I think.
