It is currently Sun Apr 19, 2015 5:23 am
 Post subject: Best pre-built bang 4 your buck
PostPosted: Tue Sep 24, 2013 2:41 pm
Looking at an xps 8700. Is there a better deal out there for what you would get, current price is $700 out the door! Basically what I am asking is, will 700$ get me more of a computer then this setup?
 Post subject: Re: Best pre-built bang 4 your buck
PostPosted: Tue Sep 24, 2013 3:11 pm
http://www.newegg.com/Product/Product.a ... 6883265534 Is about as good as you'll get as far as looking Newegg.
PostPosted: Tue Sep 24, 2013 3:15 pm
LatiosXT wrote:
http://www.newegg.com/Product/Product.aspx?Item=N82E16883265534 Is about as good as you'll get as far as looking Newegg.
So then the xps 8700 is the best deal that you can find?
PostPosted: Tue Sep 24, 2013 3:42 pm
No, because that Lenovo comes with a better video card.
PostPosted: Tue Sep 24, 2013 5:16 pm
So your saying an i5 with a better video card is worth more then an i7 with less of a video card? The 8700 also has a higher rated psu to support future expansion...Just thinking outloud.
PostPosted: Tue Sep 24, 2013 6:07 pm
The $700 configuration you chose only comes with a i5-4430. But otherwise yes, for gaming, a better GPU is far more better than a better CPU. A Core i3 with a GTX 760 will still get 60FPS on maximum settings at 1080p for most games, whereas if you gotten a Core i7 with a GTX 650, you'll start to fall off on more demanding games. And the XPS comes with a 7570, which is worse than the bottom most tier people will recommend with video cards.
Though I didn't see the power supply and 280W is cutting it close if you put in higher end parts.
