It is currently Sat Apr 25, 2015 12:47 pm
 Post subject: Building a PC, tweak my build?
PostPosted: Sat Sep 21, 2013 2:46 pm
Hello, I've been wanting a pc for a long time and have picked out two builds, I was wondering if you could tell me if I had anything missing, tell me what parts I could switch out to get more bang for my buck, Or just give me another build all together :o
First
http://www.newegg.com/Product/ComboDeal ... 13-130-637
http://www.newegg.com/Product/Product.a ... 6819113327
http://www.newegg.com/Product/Product.a ... 6811147153
http://www.newegg.com/Product/Product.a ... 6817151096
http://www.newegg.com/Product/Product.a ... 6827106289
http://www.newegg.com/Product/Product.a ... 6820313394
http://www.newegg.com/Product/Product.a ... 6822145299
http://www.newegg.com/Product/Product.a ... 6820248017
http://www.newegg.com/Product/Product.a ... 6814161404
Second
http://pcpartpicker.com/p/1zibm
THANKS :D
 Post subject: Re: Building a PC, tweak my build?
PostPosted: Sat Sep 21, 2013 4:14 pm
I'd go with the second one, it has more raw performance than the first one.
PostPosted: Tue Sep 24, 2013 6:44 pm
And is there any parts i should swap with something else to get better bang for the buck?
PostPosted: Tue Sep 24, 2013 7:02 pm
I know you can get RAM of the same specs from Patriot or Corsair for $20 less.
