It is currently Thu Mar 26, 2015 10:19 pm
 Post subject: Custom build vs pre built?
PostPosted: Thu Sep 19, 2013 10:34 am
So I got a computer built with all my parts picked out with an i5 processor and it came in at around $700.
But dell sells the xps 8700 for 750 with the i7 haswell processor and a gpu!
So my question is would I be able to make changes to a pre built computer like I would if I built it myself (ie. swap monos, install a new gpu, etc)???
 Post subject: Re: Custom build vs pre built?
PostPosted: Thu Sep 19, 2013 11:10 am
The reason why it's that cheap...
  • Dell gets volume discounts on everything. Including the OS which is like $10-$20 a license to them versus $100 a license for us.
  • The GPU is nowhere near fitting for a "extreme performance system" that XPS stands for. It's a HD7570, that's worse than a $100 card.
  • They more than likely skimp on everything else.
Also I don't understand your question, but I'm going to assume you meant "what" instead of "why", but you should be able to do the same thing to a Dell as you would a regular desktop computer now and days.
PostPosted: Thu Sep 19, 2013 12:13 pm
I don't do any hardcore gaming, the only thing it will be used for playing league of legends.
I think if you can get an i7 haswell with 12gb of ram and a 1 tb of hdd your set for a while with all the possibilities of upgrading to whatever you want...any one here think this is not the best bang for the buck?
PostPosted: Thu Sep 19, 2013 12:39 pm
If the most taxing thing you'll do is League, then you can get something cheaper and it'll last you as long. Every day tasks are a joke to run on modern processors.
PostPosted: Sun Sep 22, 2013 11:11 am
I'm with Latios on this. If MOBAs are similar, my brother plays DOTA2 on a $700 HP laptop with Core i5 CPU and integrated gfx. You can probably get a cheaper prebuilt PC than an XPS or you can build your own budget PC.
