It is currently Sun Jan 25, 2015 4:56 am
 Post subject: SLI Question+
PostPosted: Wed Sep 18, 2013 8:42 pm
Hey guys, I have a question RE: sli. Though I've been a pc hobbiest for a few years now I have never dealt with SLI or Crossfire as I'm not much of a gamer, I basically just build and upgrade for "bragging rights" to mess with my nephew. :wink: I'll list my system specs here for your perusal:
GByte GA-990FXA-UD3
AMD FX-8120 at stock(3.1Ghz)
G-Skill PC1800(?) 8GB ram
Zalman CNSP 110mm cpu cooler
EVGA GTX 680 SC+ 2GB
So here's my question; I know that this particular gpu is no longer in stock, but there are newer 680's that are faster. Can I use the older gpu with one of the newer ones without prob's, are will i have to have 2 of the same vintage?
I'm also doubling the mem to 16GB. Are there any other parts that may need an upgrade? Am open to all thoughts and suggestions.
 Post subject: Re: SLI Question+
PostPosted: Thu Sep 19, 2013 12:40 pm
I believe any GTX 680 will do, but the faster card will slow itself down to match the slower card.
PostPosted: Thu Sep 19, 2013 9:07 pm
Thanks for that verification, I figured that would be the case but wasn't sure. Now when I bought this card a year or two ago it was believed to be the sweet spot between cost and performance, how far if any has it fallen? Just a question. Thanks again for the response.
PostPosted: Thu Sep 19, 2013 10:55 pm
Oh wait, sorry. It has to be a GTX 680 of the same memory size.
PostPosted: Fri Sep 20, 2013 10:33 am
So I'll have to find one with 2GB memory? are they still available? Maybe at NewEgg? I'll take a look. Thanks
One other thing, does it matter if one is PCI 3.0 and the other 2.0? Will they just run at the slower speed?
PostPosted: Fri Sep 20, 2013 11:56 am
PCI Express version doesn't really matter because they don't start choking until you're going below a x4 PCIe 2.0 slot.
