It is currently Mon Mar 30, 2015 10:18 am
 Post subject: SSD as Cache
PostPosted: Tue Sep 17, 2013 3:16 pm
I have asked this for the last few podcasts, but they haven't gotten to it, so I figured I'd ask here.
I know that with the Z68 and up chipsets you can use a small SSD as a cache for a mechanical HD. My question is, could you take a 128GB SSD and partition it into 2, one to use as a cache for a mechanical HS and use the other part for the OS? Anyone know if this is possible?
Thanks,
atr
 Post subject: Re: SSD as Cache
PostPosted: Tue Sep 17, 2013 3:43 pm
I don't know much about this but if you do this, is it set up in the BIOS/software? Are you assigning a disk to be a cache? It sounds to me like you can set a partition to be the cache. Maybe select the the correct disk in the options menu?
PostPosted: Tue Sep 17, 2013 3:55 pm
If I recall, the SSD used for cache can only use 32GB for SRT. So yes, it should be possible.
