It is currently Sun Apr 26, 2015 7:55 am
 Post subject: Question about psu's
PostPosted: Tue Sep 17, 2013 1:03 pm
So I'll be running a core i5 haswell with 4600 integrated graphics, every calc I've used says it requires less then 100 watts. So does this mean I can get by with 200 watt PSU For my build?
Note: I'm not running a graphics card!
 Post subject: Re: Question about psu's
PostPosted: Tue Sep 17, 2013 1:35 pm
My source says at 100% load you should get a 250W PSU with 15A@12V... So I'd get that or a 300W PSU. Note that unless you're doing a complete system burn in, your system will hardly ever be at 100% load.
PostPosted: Tue Sep 17, 2013 3:22 pm
What source are u using?
PostPosted: Tue Sep 17, 2013 3:39 pm
How much money would you save by getting a 200W over a 300W psu? I see 400W corsairs for $30 on sale. Like latios said, the PSU will not use up all potential wattage.
What's a " complete system burn in", Latios?
PostPosted: Tue Sep 17, 2013 3:43 pm
http://extreme.outervision.com/psucalculatorlite.jsp I caved in and got a pro subscription though, so I can see more stuff.
A complete system burn-in for the purposes of PSU selection is maxing out both the CPU and GPU by running say Prime95 and Furmark at the same time. Both of these max out the CPU and GPU respectively.
