It is currently Mon Jan 26, 2015 1:00 am
 Post subject: Help build the best budget gaming pc
PostPosted: Mon Sep 16, 2013 4:19 pm
This is my first build and i am currently choosing what will be my computer. Since i am new i dont know what will work the best so i need some help from more experienced people. My budget is around $750. All of the parts i have listed are on amazon. I would greatly appreciate it if you could reply and give me some suggestions for my pc, thank you.
Case: NZXT Guardian Black SECC Steel Chassis ATX Mid Tower Case 921RB-RL
Power supply:Corsair Builder Series CX 600 Watt ATX/EPS 80 PLUS (CX600)
Hard drive:WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache - WD10EZEX
Graphics card:ASUS 2GB GDDR5 DIGI+ VRM technology Graphics Cards HD7770-2GD5
RAM:Corsair Vengeance 8 GB ( 2 x 4 GB ) DDR3 1600 MHz (PC3 12800) 240-Pin DDR3 Memory Kit for Core i3, i5, i7 and Platforms SDRAM CMZ8GX3M2A1600​C9
Disc drive:Asus 24xDVD-RW Serial ATA Internal OEM Drive DRW-24B1ST (Black)
Motherboard:ASUS M5A97 R2.0 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD
Processor:AMD FD8350FRHKBOX FX-8350 FX-Series 8-Core Black Edition
Cooling:Silent 120MM Red Led Sickleflo
I do tend to lean more towards AMD than Intel but you guys can suggest anything that fits the budget.
 Post subject: Re: Help build the best budget gaming pc
PostPosted: Mon Sep 16, 2013 10:02 pm
Drop the processor to an FX-6300 or around there. Should get you some enough to get a much better GPU.
