It is currently Sun Mar 29, 2015 9:44 am
 Post subject: Budget mid-level gaming pc
PostPosted: Fri Sep 06, 2013 11:02 pm
So yeah, putting together a new pc because my old one can barely handle any new games lol. I only get like 20 fps in planetside on medium, same with just about every game made beyon 2009 lol.
So, I'd like your all's opinion on this build, price/performance wise anyway.
Asus AMD 970 AM3+ mobo- $99.99
http://www.newegg.com/Product/Product.a ... 6813131873
AMD FX-6300 6-core processor 3.5ghz- $119.99 (might overclock, but probably wait till I get extra case fans and maybe a better cooler before I do that)
http://www.newegg.com/Product/Product.a ... 6819113286
Mushkin Blackline Enhanced 8gb kit (2x4gb)- 73.99
http://www.newegg.com/Product/Product.a ... 6820226191
2tb seagate barricuda- $99.99
http://www.newegg.com/Product/Product.a ... 6822148910
Cooler Master seidon 120m- $54.99
http://www.newegg.com/Product/Product.a ... 6835103179
SeaSonic 620w 80plus bronze modular Active PFC psu- 79.99
http://www.newegg.com/Product/Product.a ... 6817151095
evga GeForce GTX 760 2gb gpu- $249.99 (eventually going to buy another one and put them in sli)
http://www.newegg.com/Product/Product.a ... 6814130935
Fractal Design R4 w/window- $89.99
http://www.newegg.com/Product/Product.a ... 6811352021
also got a 30 dollar 300mb/s wifi card and 16 dollar dvd drive because why the hell not, lol.
also got batman arkham origins for free, so woot.
The worst part about this now is redownloading my steam library lol.
Comments, broseidons?
 Post subject: Re: Budget mid-level gaming pc
PostPosted: Sat Sep 07, 2013 10:33 am
How much are you willing to spend total?
PostPosted: Sat Sep 07, 2013 1:18 pm
Hard cap of $1000. Can't even go over that by a dollar lol.
PostPosted: Sat Sep 07, 2013 1:30 pm
If you can take the $50 hit up front (the total is actually $1045) and wait for rebates, then here you go.
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor ($189.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Outlet PC)
Motherboard: Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard ($159.99 @ Newegg)
Memory: Corsair XMS3 8GB (2 x 4GB) DDR3-1600 Memory ($64.99 @ Microcenter)
Storage: Samsung 840 Series 120GB 2.5" Solid State Disk ($89.99 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($83.98 @ Outlet PC)
Video Card: EVGA GeForce GTX 760 2GB Video Card ($249.99 @ Newegg)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: SeaSonic S12II 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($71.30 @ Newegg)
Total: $990.20
(Generated by PCPartPicker 2013-09-07 17:29 EDT-0400)
PostPosted: Sat Sep 07, 2013 1:57 pm
The problem is that I cannot wait for rebates. The grand total at the time of purchase HAS to be under $1000 or at least exactly $1000.
Not that that means I won't be upgrading this as I get more money. Just not until after its build and I have more saved up. The actual build is a going to college gift from my parents lol.
I'll eventually put an ssd in there. Probably upgrade to one of the new amd processors(probably the amd FX 9370) probably going to throw a better psu in there when I get a second graphics card.
PostPosted: Sat Sep 07, 2013 2:26 pm
Welcome to the forums and good luck on your new build. Just some general comments:
I think AMD is a great, low cost option for a gaming build and that 6300 is perfect. If you're familiar with overclocking, then the CPU cooler you have should give you plenty of headroom, so I don't see why you would want a bigger/better one...?
The RAM seems pricey, but it gets good reviews. If you haven't already purchased it, I would shop around. AMD actually came out with it's own brand of memory, but I couldn't find any that were available. Depending on the price, could be an option.
Quote:
... (eventually going to buy another one and put them in sli)
Not with that motherboard you're not: http://www.asus.com/Motherboards/M5A97_R20/#specifications
I like the case - it's sleek, elegant and not gaudy. It says it comes with 2 fans (though I could only see the one in the back). If one's in the front, I would move it - the front cover will hinder airflow. Personally, I would make sure one of the fans is blowing air INTO the case (and I'm even thinking having both blow into the case would be a good idea). I'd rather have a more "active" cooling scenario where cold air is being blown in, than "passive" cooling where warm air is being blown out.
Hope this helps.
BTW - see if you can delete your other thread - you have two with the exact same comments.
PostPosted: Sat Sep 07, 2013 4:14 pm
Hope this helps.
I really should have went over that mobos specs better lol. I totally missed that, and now I feel like a total nub, lol. Especially after going for that mobo instead of the asrock I was originally gonna get.
I'll probably have both fans blow in until I get more fans for it. I do have all of it bought, actually. I had a better deal for the ram but it went out of stock right before I went to buy it.
Well, other than my slight oversight in picking the motherboard, I'm pretty happy with what I picked out, lol. I may either get a better mobo and put two 760's in sli, or get a 780, whichever is cheaper at the time.
I'll try to get the other thread deleted. Not quite sure how I duped it, lol.
PostPosted: Wed Sep 11, 2013 8:42 am
From the reading and research I've done for my own $1,100. build, I think that when you put in a second GPU you will need a bigger PSU, unless that CPU really uses a whole let less power than the i5-4670K. The eXtreme power calculator recommendation for my similar build is 650w for overclocking to 4.5MHz, and 750w if adding a second GTX 660. And I'm not sure, but I think my build might use a little less power than yours. But I'm just a reader, not a tech.
Frank
PostPosted: Wed Sep 11, 2013 8:58 am
I had a computer with two GTX 560 TI's and it didn't eat up anymore than 330W off the wall. 650W is actually still okay. I'm lead to believe while eXtreme's PSU calculator is very handy, the default setting isn't exactly "real world" because you almost never tax your system that much.
PostPosted: Wed Sep 11, 2013 9:55 am
Million Club - 20 Plus
I think they shade towards the more is better side on their calculations.
PostPosted: Wed Sep 11, 2013 9:58 am
@ Latios:
Thanks. The whole topic of PSU selection is confusing to me, as the manufacturers don't seem to follow a global standard in their wattage ratings, and the fact that it's really amperage we should be concerned about, not so much wattage. Looks to me like following the eXtreme calculator's recommendations will ensure a more than big enough PSU for the build, but won't ensure efficiency. In the case of my own build I know that I won't SLI any time soon, if ever, and a quality 650w PSU is probably more than sufficient. But there is still a consideration for using a 750w unit just to be sure that I won't have to replace it if I should go SLI. I'll probably go with a Corsair or SeaSonic mid-level 650w unit.
This is fascinating stuff. Glad you guys are here. BTW, I've been a MaxPC mag subscriber for several years. The Dream Machine 2013 piece cracked me up.
Frank
