It is currently Mon Mar 30, 2015 3:09 pm
 Post subject: New Gaming Build Suggestions
PostPosted: Thu Sep 05, 2013 6:12 pm
So its finally time for me to upgrade with BF4 around the corner. Gonna reuse a few parts from my current rig. I would appreciate any suggestions/advice. Also not sure what monitors to get. I am currently using 2 Samsung T190's. They are working fine but wouldn't mind a better screen to go with the better GFX card.
Also stuck between the 4670K and the 4770K.
CPU: Intel Core i5 4670K ~ $200
http://www.microcenter.com/single_product_results.aspx?sku=583302
or
Core i7 4770K ~ $280
http://www.microcenter.com/single_product_results.aspx?sku=583369
CPU Cooling: CORSAIR Hydro series H60 ~ $65
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181030
Motherboard: GIGABYTE GA-Z87X-UD4H ~ $145
http://www.microcenter.com/single_product_results.aspx?sku=614941
RAM: CORSAIR Vengeance 16GB DDR3 1600 (Reusing current)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233299
GFX Card: SAPPHIRE 100351SR Radeon HD 7970 ~ $325
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202008
Monitor: Unsure, any suggestions?
Soundcard: Creative Sound Blaster X-Fi XtremeGamer (Reusing current)
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102006
SSD: SAMSUNG 840 Pro Series MZ-7PD256BW 256GB ~ $240
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147193
HDD: 2x WD 640GB in Raid 0 + WD 1TB Backup drive (Reusing current)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Optical Drive: LG DVD Burner (Reusing current)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136167
PSU: Corsair TX750W (Reusing Current)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Case: Thermaltake SOPRANO ~ $114
http://www.microcenter.com/product/404952/Silent_Soprano_Mid_Tower_ATX_Computer_Case
Total = $1088 or $1169
Update 1: Changed CPU and MOBO
Update 2: CPU Cooler
Update 3: GFX Card
Last edited by monsterenergy22 on Fri Sep 06, 2013 8:51 am, edited 1 time in total.
 Post subject: Re: New Gaming Build Suggestions
PostPosted: Fri Sep 06, 2013 8:20 am
Go with the Core i5-4670K and I'd go with a Cooler Master Hyper 212 instead of the H50, because I feel like water cooling, unless you're doing heavy overclocking, really buys much.
As for monitors, find a relatively cheap IPS monitor. I know ASUS makes one. Otherwise the only one I can recommend since I use it Dell's U2412M.
PostPosted: Fri Sep 06, 2013 8:35 am
Thanks for the reply.
Im definitely leaning towards the i5 now and I plan on doing a little overclocking. Not too much, but I also am going for a quieter system with this build which is why I chose the water cooling.
Thanks for the monitor input, will start looking at some IPS monitors.
PostPosted: Fri Sep 06, 2013 8:41 am
Water cooling doesn't automatically grant you a quieter system. You still have a fan and now you've added a pump into the mix. Also in my experience, CPU fan noise is not the source noise during a loaded system, it's usually the GPU.
PostPosted: Fri Sep 06, 2013 8:51 am
Mhmm good point, guess I will do some more research.
PostPosted: Wed Sep 11, 2013 9:41 am
Parts ordered and ended up going with the Hyper 212 Evo.
Thanks for all the help!
