It is currently Sun Feb 01, 2015 3:10 am
 Post subject: I wanna build a gamming pc (at least better than a ps4).HELP
PostPosted: Wed Aug 28, 2013 6:26 pm
i can't spend more than $1000 and i need a gaming pc which i have to start from scratch. it should be better than a ps4 and i want to know what is the better i can afford with that amount of money. if know a cheaper pc that i could build (better than a ps4) i would be happy to hear that. escuse my english :)
 Post subject: Re: I wanna build a gamming pc (at least better than a ps4).
PostPosted: Tue Sep 03, 2013 3:09 pm
Assuming you just need the tower, no OS:
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($144.99 @ Newegg)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard ($127.99 @ Microcenter)
Memory: Corsair XMS3 8GB (2 x 4GB) DDR3-1600 Memory ($55.99 @ Newegg)
Storage: Samsung 840 Series 120GB 2.5" Solid State Disk ($92.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($76.98 @ SuperBiiz)
Video Card: Gigabyte Radeon HD 7970 GHz Edition 3GB Video Card ($353.98 @ Newegg)
Case: Corsair 500R White ATX Mid Tower Case ($74.99 @ Newegg)
Power Supply: SeaSonic 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($79.99 @ Newegg)
Total: $1005.90
(Generated by PCPartPicker 2013-09-03 19:08 EDT-0400)
It's a little over, but if you want to start skimping somewhere, the SSD should go first.
PostPosted: Tue Sep 03, 2013 3:40 pm
Million Club - 20 Plus
Another something that we need to know, do you have any accessory items? I mean do you have a mouse? keyboard? monitor? Those kinds of things.
The more we know you have the more we can concentrate on other items. If you don't have anything to start with then we will have to include those in your $1000.00 budget. That will really limit what we can suggest for you.
PostPosted: Tue Sep 03, 2013 7:07 pm
Thanks dude. I have one question. The cpu wont be a problem? Is better than a ps4?
PostPosted: Tue Sep 03, 2013 7:10 pm
LatiosXT's build is like 3 PS4s. Seriously, that is an impressive build for $1000.
If you need an OS, you'll have to lose about $100. Personally, I would:
I would try to hold onto the SSD as long as possible - makes a considerable difference.
Hope this helps.
PostPosted: Tue Sep 03, 2013 7:20 pm
Thanks, it helps a lot. I am not sure about changing the case. I need a good case, because if it has a good cooling system i dont have to spend more in fans and all that stuff. After that, which case should i use?
PostPosted: Sat Sep 07, 2013 3:26 pm
If you want a nice looking case, take a look at the fractal define r4. If you want cheaper, try an Antec 302. I got that for $50 and it's pretty good for the price.
