It is currently Tue Mar 03, 2015 12:53 am
 Post subject: Asus Sabertooth X79-USB ports & HDD/DVD connections
PostPosted: Fri Aug 09, 2013 5:48 am
Hello!
I7-3930
PNY GTX295
Sabertooth X79
Windows 7-32 bit (later will be 64-bit)
Help me, please, to connect my HDD and DVD drives to Sabertooth X79.
I have four internal WD Black, a couple years old HDD's (one of them is system drive) - no RAID and two internal DVD drives: DVD read (going to replace wth BD+RW later) and DVD+RW. Also thinking about adding SSD drive next year. N
There are 2 brown, 4 black and 2 grey USB connectors. Which way is more efficient to connect all this staff?
P.S. And also any recommendations for 4x4GB memory 1866 Mhz (this is my new built)?
 Post subject: Re: Asus Sabertooth X79-USB ports & HDD/DVD connections
PostPosted: Fri Aug 09, 2013 10:20 am
If you don't have an SSD, then plug in your drives however you want. If you have an SSD, then whatever the 6Gbps ports are is where it should be plugged in (read the manual, that's what it's there for).
As for memory: http://www.newegg.com/Product/Product.a ... 6820233330
