It is currently Tue Apr 21, 2015 12:21 am
 Post subject: Can you help me?
PostPosted: Wed Aug 07, 2013 2:27 pm
Hey guys im new to building pc's and the specs and stuff and im wondering if you guys could take a look at the specs and give me advice or let me know if the specs are good enough to run games with demanding graphic on good settings.
PC SPECS:
CPU: 2085 - Intel Core i5 3570K
CPU Cooler: 3019 - NEW! Xigmatek Dark Knight Nighthawk SD1283
Operating System: 11014 - Microsoft® Windows 7 Home Premium 64-bit
Motherboard: 4175 - Gigabyte B75M-D2V
Memory: 5041 - 8GB Corsair 1600mhz Vengeance (2x4GB)
Hard Drive: 6028 - 1TB S-ATAIII 6.0Gb/s
Optical Drive: 7003 - 22x DVD±RW DL S-ATA
Graphics card: 9042 - AMD Radeon HD 7950 3GB
Sound card: 10001 - Onboard 7.1 Audio
Internet: 13006 - Wireless 802.11N 300Mbps MIMO PCI card
Monitors: 15045 - NEW! AOC 23" i2369Vm LED
Case: 17070 - NEW! Xigmatek Asgard 382 Window
PSU: 18047 - NEW! 650W Corsair VS
All the help will be much appreciated. Thanks!
 Post subject: Re: Can you help me?
PostPosted: Thu Aug 08, 2013 5:28 pm
Welcome to the Forums! I hope you enjoy building computers as much as we do.
From a purely, "will it work together?" standpoint, the answer is "Yes." As for running demanding games, the key words you have are "good settings." Maxed out? No. High settings? Probably. A mixture of high and moderate settings? Definitely.
Also, if gaming is your main objective, consider the nVidia 760 over the 7950. There about the same price and the 760 should perform better in games.
My only question:
The list of components you have seem to be from the previous generation. Is there a specific reason you chose Ivy Bridge (3570k) over Haswell (4570k)?
Hope this helps.
Users browsing this forum: No registered users and 14 guests
