It is currently Thu Jan 29, 2015 9:25 am
 Post subject: Fan connections for my motherboard
PostPosted: Tue Aug 06, 2013 8:37 pm
Ok so you most likely saw my prior post for the buidl I am doing I suddenly find myself trying to find out info my motherboard i picked doeisnt give.
ASRock Z77 Extreme4 LGA 1155 Intel Z77 is the one I originally went with. But now I am trying to be sure it can run all my case fans and the CPU fan but don't know.
I have 3x 200mm case fans [one intake, one top exhaust and one side] and a single 140mm top rear exhaust fan also going to have a Hyper 212 evo form cooler master on my CPU so another 120mm fan.Will this mobo support them all or shall i use my PUS? or buy another Mobo all together save myself the headach? Thanks alot in advance.
 Post subject: Re: Fan connections for my motherboard
PostPosted: Wed Aug 07, 2013 3:20 am
The ASRock 1155 I looked at had 4 chassis fan connectors (2 middle, 1 top, 1 bottom) and 2 CPU fan connectors (both top). In theory, they should accommodate the fans you mentioned, though I would suggest connecting the side fan to a molex adapter and run it off the PSU - it makes removing the side panel much easier.
Speaking of...you mention 3 200mm fans - what case are you using? I'm curious.
Hope this helps.
PostPosted: Wed Aug 07, 2013 4:58 am
I am using the cooler master HAF 922 with polans for an optional 200mm side fan I mostly want to be sure my fan plans well done.
PostPosted: Wed Aug 07, 2013 2:55 pm
Not sure you need the side fan as In my opinion it will disrupt the air flow anyway. I Have a 200mm in front for intake, 1 120mm in the rear and 2 120mms on top for exhaust and things stay plenty cool ( Cooler Master 912 HAF case ).
