It is currently Fri Apr 17, 2015 10:12 pm
 Post subject: GPU Comparisons?
PostPosted: Thu Aug 01, 2013 2:44 pm
Does anyone out there know of a website that allows one to compare GPU benchmarks over a greater period of time than, say, anandtech's lackluster "bench" tool?
I have a 6870/6850 crossfire setup but I can't compare it to many modern GPU setups as the bench tool only allows a 68XX crossfire setup to be compared to GPUs from several years ago. I can compare a 68XX to a modern Nvidia/AMD gpu but that literally gives me only ~half the "story".
 Post subject: Re: GPU Comparisons?
PostPosted: Thu Aug 01, 2013 3:12 pm
You're only hope for what you're looking for is going on Futuremark and looking at scores there. But even then this is kind of a wash because 3DMark scores don't really mean much in the big picture.
Otherwise, you'll have to find a more modern GPU that has comparable performance numbers and use that as your baseline.
PostPosted: Thu Aug 01, 2013 4:03 pm
I don't think it will help too much since they just got the site up and running in the last year or so and their data on GPUs even a generation ago is limited, but you can try GPUboss.com.
Hope this helps.
