It is currently Thu Mar 26, 2015 9:52 pm
 Post subject: GPU upgrade
PostPosted: Thu Jul 25, 2013 7:37 am
I'm going to upgrade to the new haswell CPU. My question is this I'm currently gtx 560ti in SLI. and was wonder if my research was current or did I miss something here is what I found
GTX 560ti in SLI can beat a GTX 670
and GTX 670 run parallel to a GTX 760.
So is there real performance difference between the GTX 560ti in SLI to the new GTX 760.
Could really use some help
thanks
 Post subject: Re: GPU upgrade
PostPosted: Sun Jul 28, 2013 6:46 pm
I went from two 560 Ti's to a GTX 670. Mostly because I was getting annoyed that the 560 Ti's ran really hot and loud. But I noticed some other subtle differences. For instance, I noticed that in Skyrim I was getting smoother performance (with my setup, it would constantly stutter, with a single GTX 670 it never did). And I think I felt like I was getting smoother performance overall.
So you probably will get some subtle, more pleasant changes like this. GPU performance now isn't always about FPS (especially since multi-GPU setups have this thing called microstuttering)
