It is currently Sun May 03, 2015 11:12 pm
 Post subject: Upgrade my RAM
PostPosted: Tue Jul 23, 2013 7:23 am
Hello all,
I would like to upgrade my RAM to 24GB heres the thing though. I have a old 1366 mobo with 3x2GB modules and I need more RAM for a project Im working on. I will build a new comp once Haswell comes out. Can I add RAM to my GA-EX58-UD5 with RAM that I will use in the new Haswell system in the future.
Thank you for any help!
 Post subject: Re: Upgrade my RAM
PostPosted: Tue Jul 23, 2013 8:52 am
Yes, they both use DDR3. However, Haswell boards only have 4 RAM slots and may only support at most 16GB of RAM.
PostPosted: Tue Jul 23, 2013 9:19 am
Thanks for the response. I did notice that when looking at some of the boards. I did find single 8GB sticks so eventually I can get up to 32GB of RAM if my thinking is right?
http://pcpartpicker.com/part/corsair-memory-cmv16gx3m2a1600c11
http://pcpartpicker.com/part/corsair-memory-cmv8gx3m1a1600c11
Or these
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231558
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231568
What do you think
Thanks for all the help!!
PostPosted: Tue Jul 23, 2013 9:59 am
You can also find 8GBx2 kits. And most ATX boards support 32GB unlike I previously thought.
PostPosted: Tue Jul 23, 2013 10:10 pm
Question can your OS support more than 16gbs? If not it won't matter what the mobo can run your OS will be unable to address it.
PostPosted: Tue Jul 23, 2013 10:22 pm
Which for Windows is the Pro version or better.
PostPosted: Wed Jul 24, 2013 11:29 am
Correct Latios if you don't have it [and you need to have the 64 bit version 32 bit versions remain stuck at a max of 4gbs that may be addressed.] So it'd be my first question as stated.
PostPosted: Fri Jul 26, 2013 3:11 am
Im running Windows 7x64bit and I mainly use Adobe After Effects CS6. I put the new RAM in however it wont boot if I have my older RAM inside with it (G.Skill DDR3-1600-PC3-12800 2GBx3 CL9-9-9-24 1.5v). The only thing different between the two are the CL rating (10-10-10-30) and of course the memory size 8GBx2.
Why would it not boot? When I just put either set by themselves in the slots the comp will boot fine.
Thanks!
PostPosted: Fri Jul 26, 2013 7:32 am
Part of me is thinking because you got a dual channel kit instead of a triple channel kit, the memory controller isn't liking having five sticks of ram when it was expecting six. Either way, it may be really strict on how you populate those slots.
PostPosted: Fri Jul 26, 2013 9:43 am
Which version of windows 7x, home,pro?
PostPosted: Fri Jul 26, 2013 2:46 pm
DiRTDOG wrote:
.... my older RAM inside with it (G.Skill DDR3-1600-PC3-12800 2GBx3 CL9-9-9-24 1.5v). The only thing different between the two are the CL rating (10-10-10-30) ....
edit: I just remembered, the memory controller on the 1366 CPU's doesn't recognize 8Gb sticks. The most you can have is 24Gb in a 6 x 4Gb arrangement.
This assumes they are the same voltage and 1,600MHz speed. Or you can buy these and forgo the gymnastics though I'd still make sure the BIOS is updated to F13 before the addition.
1. Update the BIOS to the last version available for your MB if not already up to date.
2. Then install the slower 3 x 4Gb in the A channel and the faster 3 x 2Gb in the B channel. You will have to look in your MB manual for which configuration(s) are acceptable for a 1+ 1 + 1 x 1 + 1+ 1 triple channel arrangement on a six RAM slot 1366 MB and which channel is the first channel?
You can buy a 2 x 4Gb + an identical 4Gb stick or three (or six) of the same 4Gb sticks (probably easier). It matters not.
3. If it still won't stably boot. Remove the 3 x 2Gb and boot into the BIOS menu and manually change timings to 1,600 (10-10-10-30), save and exit. Shutdown, install other RAM in B channel and reboot.
4. If it still won't work, I'd repeat step 2, do a CMOS reset per MB manual and then step 3.
PostPosted: Sat Jul 27, 2013 2:45 am
@tellos: its win 7x64 Pro
@FascistNation: I will give that a try this weekend the Mobo is on the latest FW so that step is out of the way. The 2 8GB sticks are being recognized I am using them now and they are at 1600mhz. I will try the rest of your instruction and post the results.
Thanks!
PostPosted: Sat Jul 27, 2013 11:12 am
DiRTDOG wrote:
....The 2 8GB sticks are being recognized ....
That is good to know. I assume adding a 3rd identical stick in the same channel would max it out.
You can try adding the old RAM back but keep in mind only two sticks can go in (it will run in dual channel), if you add the fifth stick it will all run in single channel mode and the MB manual may have a required pattern for 5 sticks (or even 4). The performance hit between dual and triple channel was negligible. Between dual and single was not great but not so negligible. It is the difference between running 20Gb or 22Gb.
So what to do with all that RAM?
PostPosted: Sun Jul 28, 2013 4:02 am
Thanks everyone got it up and running. I had to put the older RAM in the 1 and 3 channel and the new RAM in 2 and 4, any other config the system wont boot. I didnt have to mess with the timing so its all good for right now. If I add the 5th stick it wont boot, 20GB or RAM is enough right now for my project it seems. I will MAX out at 32 when I build my Haswell machine.
Thanks again.
