It is currently Wed Mar 04, 2015 11:27 am
 Post subject: Newb quest: Seagate 1TB SATA SSD/Hybrid 2.5" OK in Desktop?
PostPosted: Mon Jul 22, 2013 11:13 am
There are some nice deals on Seagate's 1TB Solid State/Hybrid Drive -- SATA 6Gbps 64MB Cache 2.5-Inch ST1000LM014. I like the price/specs ratio.
Newb question: Can this drive be used as the primary mass storage in a desktop build?
Thanks in advance,
Jeff
 Post subject: Re: Newb quest: Seagate 1TB SATA SSD/Hybrid 2.5" OK in Deskt
PostPosted: Fri Jul 26, 2013 11:13 pm
Your question is a little ambiguous. Using the term "primary" usually means your OS drive (your C: drive). On the flip side, "mass storage" typically refers to a different drive (like a D: drive). I think you mean the latter (the D: drive). If that's the case, I'm not sure a hybrid is a good idea.
The benefit of the hybrid is (over time) it "learns" what you access the most. That information is stored on the SSD part while the lesser accessed stuff is stored on the standard HDD. For an OS drive (or for a system with just one drive), this is a decent option - the OS would reside on the SSD part (with some frequently used applications) with data on the HDD. As a mass storage device, I think you would be accessing different data all the time which means your data may (or may not) be on the SSD, thus limiting the benefit of the hybrid drive.
Then again, if you're just asking if it's even feasible to use a hybrid drive however you're intending, my suggestion would be to see if you can find a manual online that you could read - if there are special instructions on how to set up the drive, it should be listed there. Next, check some reviews online and see if anyone mentions the ease (or difficulty) of setting up the drive.
Hope this helps.
PostPosted: Fri Jul 26, 2013 11:38 pm
Yes. You just have to get a 2.5" to 3.5" mounting bracket if your case doesn't have 2.5" mounting brackets.
