It is currently Sat Feb 28, 2015 8:15 am
 Post subject: PC build around these parts
PostPosted: Thu Jul 18, 2013 9:40 pm
Hey Guys,
This is going to be my first ever Gaming PC build. I've seen countless tutorials and guides and I think im confident to take my first plunge into creating a gaming PC.
(Plus I'm new to the forums, forgive me if this is the wrong place to put this!)
The 4 parts I'm basing my build on are thee:
1) "Azza HURRICAN 2000 Full Tower Computer Case" [http://azzatek.com/csaz-2000-techspec.html], [http://www.newegg.com/Product/Product.aspx?Item=N82E16811517010]
2) "Intel Core i7-4770K CPU" [http://amzn.to/Zz3s5v], [http://www.newegg.com/Product/Product.aspx?Item=N82E16819116901]
3) "EVGA GeForce GTX 780" [http://amzn.to/16QEJyY], [http://www.newegg.com/Product/Product.aspx?Item=N82E16814130916]
4) "CORSAIR H100i Water Cooler" [http://www.newegg.com/Product/Product.aspx?Item=N82E16835181032]
Basically, I'm going with with good game performance mixed with the best cooling I can get. For me though system cooling would be my top priority. I would rather have a more noisier system then a hotter one. As you can see there are major parts missing like the mother board and power supply. I've done a lot of research and I have a couple of motherboards in mind, but I am taking all suggestions into great consideration before I okay my build. Also I'm clueless when it comes to power supply's. I think the part that's going to worry me is connecting the power supply to the mother board, I'll just read the motherboards manual very carefully.
Budget is ($1500-$2000) including listed parts. Willing to stretch a bit if you guys suggest parts that would be worth spending.
Well, there you have it! If you guys have any suggestions on good motherboards, coolers, power supply's, etc... that would complement these parts please let me know! Thanks guys, Appreciate it!
 Post subject: Re: PC build around these parts
PostPosted: Sun Jul 21, 2013 12:04 am
Actually, after doing some more browsing I think I'm gunna scrap the 780 and do and SLI with two 770's instead! How big of a power supply would I need to get if im going to do a two or three way SLI in my build???
