It is currently Thu Mar 26, 2015 2:48 pm
 Post subject: I have some questions about the GTX 780
PostPosted: Tue Jul 16, 2013 8:39 am
I want to get it and I finally have the money. I have a few questions before I do buy it though.
1) Will a 650 watt PSU be enough? I currently have the following PSU: 650 Watt -- NZXT HALE82N-SI / 80+ Bronze
2) Will it fit in PC? I read that space is an issue. My tower is: Chimera Inferno 4SE Gaming Case - Flame, from ibuypower. Its a pretty big case, though not nearly the biggest I've seen. Definitely bigger than an everyday case though. I currently have the GTX 650, so I assume it would be around the same size. I have no idea though.
3) How does SLI work, and would this card work in SLI with my current 650? Should I try hooking them together if I get it, or would it be a waste of time?
4) Finally, are there any deals on it anywhere? I see it on newegg for about 650, but thats without shipping and a warranty.
 Post subject: Re: I have some questions about the GTX 780
PostPosted: Tue Jul 16, 2013 1:42 pm
Yes.
The card is 10.5 inches long, so reserve about 11 for breathing room.
SLI only works with identical GPUs.
Do some shopping at other vendors, like TigerDirect, Fry's, Microcenter, etc.
Users browsing this forum: PCNoobiee and 9 guests
