It is currently Sun Feb 01, 2015 4:55 am
 Post subject: Are these parts compatible?
PostPosted: Fri Jul 12, 2013 3:12 pm
Hello
I'm about to buy a pc made of the following parts. My budget is 1200 euros. Is everything ok with these or should i change something?
http://gyazo.com/4db02ef2fad9888f04c4234fdfd220f6
+ Fractal Design R4
+ Windows 7/8
Thanks in advance
 Post subject: Re: Are these parts compatible?
PostPosted: Fri Jul 12, 2013 8:00 pm
Looks good - everything is compatible.
The RAM seems expensive (but I don't know how much RAM costs in Europe so I could be way off).
You mention 1200 and your graphic shows 947 (not sure if you're including the case and OS in the 1200), but if you have any money left in your budget, I would try to get a bigger SSD. 256 is the new sweet spot and I'm guessing you could get an Samsung 840, Corsair or another good brand for about 50 euro more. Probably worth it.
Hope this helps.
PostPosted: Fri Jul 12, 2013 10:21 pm
Thanks for the reply!
Ram is one of the cheapest quality rams i found. Yeah that 1200 includes also the case on os, so therefore getting bigger ssd is not possible. One thing i could and might do is to get non pro version of this motherboard and save 30 euros and get noctua the ND-H14. What do you think?
PostPosted: Sat Jul 13, 2013 12:44 pm
Get the motherboard that fits your needs whether it's the Pro version or the cheaper alternative.
As for the CPU cooler, you've already selected a decent one already. Are you planning on overclocking? If so, see if you can find some comparisons to see if it's truly necessary. If you're not, then the one you selected should be adequate. Ultimately, it's your call.
I would be remiss if I didn't say that the $30 could gets you closer to a 256 SSD.
Hope this helps.
