It is currently Tue May 05, 2015 5:39 pm
 Post subject: New Pc build won't power on?
PostPosted: Tue Jul 09, 2013 11:27 am
I have looked at the checklist on this site first but nothing has worked.
I just built my PC and will not turn on at all, no beep nothing. There Green LED light on the motherboard is on tho as is the video card light. Once when I tried to turn it on the fan moved for about 1 second then died again. Im pretty sure all the cables are right.
Im hoping nothing is broken and i just used a wrong cable somewhere?
I made a quick video just showing the cables.
http://www.youtube.com/watch?v=OsJqBIMFGHw
Thanks Guys!
Build
ASUS GTX 770
CPU i7
ASUS MOBO P8Z77 - V
Fractel Case Define R4
SilverStone Gold 850
16GB RAM
SSD DRIVE 256
DVD ROM
SATA Hard Disk
Intell Liquid Cooler
 Post subject: Re: New Pc build won't power on?
PostPosted: Tue Jul 09, 2013 5:16 pm
If you've tried taking out everything but one stick of RAM, CPU, and video card and it still doesn't boot, I'd just replace the PSU.
PostPosted: Tue Jul 09, 2013 7:33 pm
I would also check the standoffs and perhaps see if it will boot with the motherboard out of the case. I would also check and make sure there are no bent pins in the socket.
