It is currently Sun Apr 26, 2015 11:59 am
 Post subject: Will this rig be good for gaming?
PostPosted: Sun Jul 07, 2013 1:45 pm
I found a pretty good build to start with please tell me if this will be good for gaming. The parts are AMD A8-5600K Trinity 3.6GHz (3.9GHz Turbo) APU (CPU + GPU) with Graphic Radeon HD 7560D, ASUS F2A55-M LE Micro ATX Motherboard, CORSAIR XMS 4GB DDR3 Desktop Memory, Seagate 500GB 7200 RPM Hard Drive, Rosewill R519-BK ATX Mid Tower Case w/ 5. It looks good on paper , but just wondering. Also i will add another 4 gb RAM onto that and a disk drive. I might also swap the A8 for and A10 6800K APU. Thnx!
 Post subject: Re: Will this rig be good for gaming?
PostPosted: Sun Jul 07, 2013 2:18 pm
Forget APUs for gaming. If you want a good experience gaming you cannot cheap out on parts.
Maximum PC puts together several builds that are good for gaming:
http://www.maximumpc.com/build_pc_recom ... _july_2013
Choose one you can afford and build it.
The more expensive it is the more code you will see in the game via maxing everything out.
PostPosted: Sun Jul 07, 2013 2:38 pm
The problem is, im on a small budget. I was wondering how it does. Could i get maybe medium settings on a mediumish resolution with 30-60 frames? Thats all i need.
PostPosted: Sun Jul 07, 2013 2:48 pm
Mr. Late Night
Mr. Late Night
Well since the previous thread you were asking about on upgrading your Precision T3500 you indicated you wanted to play BF3 & Arma 3 I would say no. Those are two of the most graphically demanding & CPU demanding games currently on the market. If you went with the build that I proposed in that thread then yes it would be able to handle it at a medium level of detail.
PostPosted: Mon Jul 08, 2013 3:54 am
Quality comes with a price. :) You have to always invest on good products.
steve barbarich
