It is currently Mon Mar 02, 2015 11:19 am
 Post subject: First time build
PostPosted: Mon Jun 24, 2013 12:43 pm
Picked out the components for my first time build, just need confirmation all parts are compatible..could anyone take a look for me as I'm not sure!
Graphics:-
ASUS PCI-E A HD7870-DC2-2GD5-V2
Processor:-
Intel Core i5-3350P - 3.1GHz - Socket 1155
Hard disk:-
Seagate 1TB 3.5" SATA-600 7200rpm 64MB
SSD:
Samsung 840 Series 120GB
Motherboard:-
ASRock H77M - Socket 1155 - Micro-ATX
Memory:-
Corsair 4GB DDR3 1600MHz UDIMM (2x4GB = 8GB)
Case:-
Cooler Master K280
PSU:-
Corsair CX Series CX500M - 500 Watt
OS:-
Microsoft Windows 8 64-bit
Just want to make sure it will all work together and fit in the case?
Thanks!
 Post subject: Re: First time build
PostPosted: Fri Jun 28, 2013 10:56 am
Graphics:-
Processor:-
Hard disk:-
SSD:
Motherboard:-
Memory:-
Case:-
Cooler Master K280
PSU:-
OS:-
Thanks!
It will all fit, but curious as to why you went with a Micro ATX Motherboard rather than a standard ATX. You will be squeezed on the small Motherboard as it is only about 9" x 9".
PostPosted: Sun Jun 30, 2013 7:44 am
I'm not sure to be honest, I don't know much about motherboards so I was recommended that one and went with it! Have you any suggestions for others? Will a bigger one be necessary?
PostPosted: Sun Jun 30, 2013 8:05 am
Honestly, if all you're adding is a video card, you won't need much more than a Micro-ATX board. What I'm curious is why you went with an Ivy Bridge, rather than Haswell.
PostPosted: Sun Jun 30, 2013 8:19 am
I'm not sure of the difference, I think I was advised on that type because of the socket in my processor was 1155. Are the haswell models different to that? I don't really know why, is the difference big? price, performance etc?
PostPosted: Sun Jun 30, 2013 2:33 pm
There's not much of a price difference and you get slightly better performance. In all honesty it's mostly just to stay up to date.
PostPosted: Mon Jul 08, 2013 3:49 am
I have to agree. Haswell is a better choice here.
Users browsing this forum: Chunky_Chips and 4 guests
