It is currently Tue Jan 27, 2015 4:59 am
 Post subject: Building Server to Store files on a local network. What do y
PostPosted: Thu Jul 11, 2013 12:49 pm
Hello i am building a server for storing files and running Microsoft exchange for a small business. It may do more in the future. Not this is my first server build ever. What do you guys think? Any advice you could give me?
Build:
Case: SUPERMICRO CSE-743T-500B Black Pedestal Server Case
http://www.newegg.com/Product/Product.a ... 6811152241
Price: 300.00
MOBO: ASUS P8C WS ATX Server Motherboard LGA 1155 Intel C216 DDR3 1600
http://www.newegg.com/Product/Product.a ... 6813131849
Price: 240.00
Raid Controller: LSI MegaRAID SATA/SAS 9260-4i 6Gb/s PCI-Express 2.0 w/ 512MB onboard memory RAID Controller Card, Kit
http://www.newegg.com/Product/Product.a ... 6816118107
Note: I will be running raid 6. Would a different raid level be better?
Price: 360.00
CPU: Intel Xeon E3-1230 V2 Ivy Bridge 3.3GHz (3.7GHz Turbo) 4 x 256KB L2 Cache 8MB L3 Cache LGA 1155 69W Quad-Core Server Processor
http://www.newegg.com/Product/Product.a ... 6819117286
Price: 235.00
Ram: Kingston 8GB 240-Pin DDR3 SDRAM DDR3 1600 ECC Registered Server Memory DR x4 Intel Model
http://www.newegg.com/Product/Product.a ... 6820239231
Price: 76.00
Hard drive: Seagate Constellation 2 TB 3.5" Internal Hard Drive - 6Gb/s SATA - 7200 rpm - 64 MB Buffer - Secure Erase - Hot Pluggable
http://www.newegg.com/Product/Product.a ... 6822178323
Note: I will be getting 4 of these
Price per Unit: 132.00
Total: $1,738.91
Note: I don't know much about raid cards so i need some help with that. IDK if that megaraid one is any good or not.
 Post subject: Re: Building Server to Store files on a local network. What
PostPosted: Thu Jul 11, 2013 4:59 pm
Mr. Late Night
Mr. Late Night
When it comes to RAID cards I'm not a huge fan of LSi, they're not bad it's just that there are better cards out there. You might want to look at the 3Ware 9650SE-8LPML or the Areca ARC-1222 both cards are better hardware wise and tend to be better supported. I personally have a 3Ware 9550SE-8SXLP in my home server and have been quite happy with how it's performed. RAID 6 should be fine for your uses.
Asus makes good motherboards but when I build servers I tend to use either Tyan or Supermicro boards. The one you've chosen looks decent but you might also want to consider the Supermicro X9SAE-V
Other than those two items it looks like you have a pretty solid build.
PostPosted: Thu Jul 11, 2013 5:48 pm
OK thanks for your advice. I do think that SuperMicro board you linked would serve me better than the one i have selected currently. Ill look into the raid controllers you linked. Thank you :)
