It is currently Wed Mar 04, 2015 3:25 am
 Post subject: Need New Portable
PostPosted: Thu Jun 27, 2013 12:36 pm
Ok, i need some suggestions / Advice on a new Superkick A** Portable, Core Requirements are
Video as High as I can get (Will be doing heavy video and photo processing on it)
64Bit OS
Minimum of 32GB RAM, with upgrade to higher amount at later date
DVD Burner Drive
high Reliability
Minimum 16" Screen
Good Cooling
Thanks for any help
 Post subject: Re: Need New Portable
PostPosted: Thu Jun 27, 2013 6:56 pm
So some comments here...
  • Video cards don't offer media acceleration unless the application specifically supports it. And as far as I know though, even Adobe Aftereffects doesn't use it to an extensive degree and just for some effects. So I would do research on the products you're using and if they have GPU acceleration support.
  • Drop the RAM requirement. A look on Newegg showed only two laptops with it (both MSI gaming laptops). And I'm pretty certain that 32GB is the maximum limit most motherboards (as in, laptop and desktop) can support at the moment. I could be wrong for workstation desktop replacement
  • Generally 17" (there is no 16") have good cooling.
