It is currently Sun Jan 25, 2015 9:27 am
 Post subject: Help on Choosing parts
PostPosted: Fri Jul 19, 2013 12:09 pm
Hey guys!
I need some help on building a pc and i dont really know much about the parts, so i need your help!
Ok first of all, let me tell you that i want my pc to focus primarily on GAMING and it would be nice if it can support 3 monitors.
Im going to be buying the parts for my pc at a local shop, and i will get it built (i wont actually build it). He puts a list of parts on his website but he hasn't updated the website in quote a while so i wont know what are his prices until i go check at his shop. Anyway, i want my pc to be capable of running some modern/demanding games like batman/farcry 3/bioshock infinite (and if possible crysis 3) at around 60fps with 3 screens hd.
So for a graphics card i was thinking nvidia gtx 670 (or 680 if i can afford) but do i need 2 cards in sli to be able to run 3 monitors?
Now for the cores, i found the Intel core i7 3820, but im not so sure
For the ram i think 12 gigs will be enough, But again idk how much ram it will take to play on 3 monitors with a smooth 60fps
As for the motherboard i have absolutely no clue which one i need or whether they are compatible with sli.
So those are the base parts for my computer (other than the case, which, again, i need a recommendation).
Also: i cant afford to pay more than 1,700$ for it.
Thanks guys for reading it(if u read it all ;) and i appreciate any help.
 Post subject: Re: Help on Choosing parts
PostPosted: Sat Jul 20, 2013 9:34 am
http://pcpartpicker.com/p/1iITs
To start with.
