It is currently Fri Jan 30, 2015 4:47 am
 Post subject: power supply 24 pin
PostPosted: Tue Jun 18, 2013 11:49 am
i bought a new power supply but when i was trying to remove my old one the 24 pin connector would not come out and i was holding the sleeve on the side that releases it while wiggling it and it would not come out, any suggestions?
 Post subject: Re: power supply 24 pin
PostPosted: Tue Jun 18, 2013 2:04 pm
Did you make sure pull the ratchet tab?
PostPosted: Tue Jun 18, 2013 3:42 pm
yeah it just wont come off i even tried removing the other wires connected to it and they would not comes off, im starting to wonder if my power supply cant be removed.
