It is currently Wed Mar 04, 2015 11:25 am
 Post subject: Office Computer Builds?
PostPosted: Fri Jun 14, 2013 7:26 pm
My office computer is literally over ten years old. We've had a good run, but it's dying.
I have absolutely zero experience at building computers, so any insight would be appreciated. I'm looking to build a new office computer:
Use: Microsoft Office programs (Word, Excel, Access), Adobe Reader, etc.
(Note: I've had Adobe Photoshop on my computer for years, but never used it. I suppose I'd still like to have that capability, even if limited).
Budget: $400 - $450 (Shipping included, taxes extra)
Requirements: I'd really like to use an Intel i3 cpu of some sort.
Other Notes: 99% of files are saved to the main server. As such, would it make since to ditch the hard drive and go SSD alone?
Thanks for any and all suggestions!
 Post subject: Re: Office Computer Builds?
PostPosted: Sun Jun 16, 2013 10:47 am
Presumably just the box, no peripherals. And no OS---you will reuse your current?
Nope, can't in good conscience do it for a PC likely to be used another 10 years. Intel Core i3-3225 Ivy Bridge 3.3GHz LGA 1155 55W HD4000 graphics Dual-Core Processor; ASRock Z77 Pro4-M LGA 1155 Micro ATX Motherboard; Team Vulcan 8GB (2 x 4GB) 240-Pin DDR3 SDRAM 1600 (PC3 12800) Memory (Yellow Heat Spreader); SilverStone PS08B Black High-strength plastic and meshed front panel MicroATX Mid Tower Computer Case; XFX Core Edition PRO550W ATX12V 2.2 & ESP12V 2.91 80 PLUS BRONZE; SAMSUNG 840 Series 2.5" 120GB SATA III Internal Solid State Drive (SSD); LG 24X DVD Burner SATA
CPU incl. HSF, 3 yr warranty
MB 3 yr warranty, incl. 2 SATA cables
RAM lifetime warranty
CASE
PSU 5 yr warranty
SSD 3 yr warranty, 2.5" to 3.5" bracket and data transfer cable included
ODD
$540 incl s&h
Last edited by FascistNation on Sun Jun 16, 2013 11:41 am, edited 4 times in total.
PostPosted: Sun Jun 16, 2013 10:55 am
How desperate are you for a new computer? At your budget, pre-built computers with a Core i3 are very few and far between. And while you could build something with a Core i3 or even a lower end Core i5 at your budget, it doesn't include the OS or peripherals (use http://images1.wikia.nocookie.net/__cb2 ... ec2012.png , just cut out the video card and use the rest of the budget on the CPU).
If you could push it up to $600 or so, excluding shipping and tax, it'll open up a lot more doors.
PostPosted: Sun Jun 16, 2013 12:13 pm
I've raised my budget to $500 - $550. Considering my current OS is XP, I think I'll upgrade to Windows 7 (the business is in the process of doing that anyway). But yes, that needs to be included in the budget. This is what I have so far:
Case & Power Supply - Used - $70 (Currently being used for identical motherboard and an i5-3570K CPU)
CPU - Intel i3-2100 3.1 Ghz Dual Core - $120
Motherboard - Gigabyte GA-H61MA-D3V Micro ATX LGA1155 - $60
RAM - Crucial Ballistix Smart Tracer 4GB (1 x 4GB) DDR3-1600 Memory - $30
SSD - Crucial M4 64GB 2.5" Solid State Disk - $80
Drive - LG GH24NS95 DVD/CD Writer - $18
OS - Microsoft Windows 7 Professional SP1 (OEM) (64-bit) - $140
Total = $518 + Shipping & Taxes
Should anything be changed to eek out some better value or for better quality at the same or better price?
The SSD is only 64GB (20GB for OS + 20GB storage [that's about what I'm currently using] + 24GB to spare). Any issues with this? If it turns out not to be enough storage, I will be updating my personal computer with a 2TB HDD, and I could use the current 500GB HDD for my office build.
