It is currently Sat Feb 28, 2015 8:30 pm
 Post subject: PWM vs Non PWM Fan Controllers
PostPosted: Sat Jun 15, 2013 12:01 pm
Hi guys, ok so im kind of new to the whole PC fan thing, and im looking to add about 3 extra fans to my case.
I finally found out the difference between PWM fans, and non PWM and now im looking at controllers. There are 2 that i like the look of that are recomended by most people.
Now, I'm not interested in the motherboard connection as i dont think it has the connection to plug it in, i will control the fans manually so thats not a problem. I do however work on music on my pc professionally, so when im not gaming i will need to be able to switch the extra fans off to 0%.
This controller looks perfect, comes with PWM control or manual. Now my question is, can i use this and forget about the motherboard connection, just connect it to my psu and manually control the fans?
Also if i were to use this controller without using the motherboard connection, which fans would i be able to use with it? the 4 pin pwm? or 3 pin?
Kustom PCs Sunbeamtech Rheosmart 3 Fan Controller
The other controller i found was this 1, however it only goes down to 5v, and really with 3 extra fans i would need the option to turn them off completly
http://www.amazon.co.uk/Scythe-Rheobus- ... -Aluminu...
Thanks in advance guys
 Post subject: Re: PWM vs Non PWM Fan Controllers
PostPosted: Sat Jun 15, 2013 9:31 pm
The only advantage PWM based fans/controllers have is that a constant voltage is applied in a PWM fan, unlike one that isn't. This allows a PWM fan to run at lower speeds, whereas a voltage controlled fan won't work below some voltage.
Users browsing this forum: btdog and 5 guests
