It is currently Fri Apr 24, 2015 6:41 pm
 Post subject: AMD motherboard replacement!
PostPosted: Wed Jun 12, 2013 9:42 am
I'm planning to set up my whole pc but im confuse which is better choice if i just get a Good Motherboard? which brand? or better to get whole unit of CPU thats already all fix. anyone who have known something, I badly need an advice???
 Post subject: Re: AMD motherboard replacement!
PostPosted: Sat Jun 15, 2013 12:40 pm
Gigabyte, ASUS, MSi & ASRock all are pretty good brands right now. There may be some others, but these 4 should give you a good start.
Your comments are a little confusing regarding the CPU. If you're asking if you can find a CPU "built-in" to the motherboard, generally speaking the answer is "No." PC builders like the flexibility of being able to select what CPUs they put in their computer. Research is key when building a computer.
Keep reading the web forums. Also, start looking at adds and computer shopping websites (like Newegg.com) so you can familiarize yourself with the computer components. LatiosXT just posted this on another topic, but you may find it useful as well. It's not all inclusive in what you need but it covers the basics:
http://images1.wikia.nocookie.net/__cb20121225224246/4changboard/images/7/76/Falconguide-dec2012.png
Hope this helps.
