It is currently Tue Mar 31, 2015 4:06 pm
 Post subject: Overheating FX-8350
PostPosted: Wed May 29, 2013 1:09 pm
Hello everyone :D
Today I got my brand new FX-8350 in the mail!
Install went smoothly. I am using the CM Hyper 212 Evo cooler (With push-pull, http://www.newegg.com/Product/Product.a ... 6835553001) and the thermal paste that comes with it (Yes yes I know, but I ran out of my other stuff :P)
The temps are really bothering me though:
Min Max Average
Core0 25.88| 55.12| 44.29
Core1 25.88| 55.12| 44.31
Core2 25.88| 55.12| 44.31
Core3 25.88| 55.12| 44.31
Core4 25.88| 55.12| 44.31
Core5 25.88| 55.12| 44.31
Core6 25.88| 55.12| 44.31
Core7 25.88| 55.12| 44.31
TMPIN0 47.00| 64.00| 54.60
As of this moment I am sitting "idle" at 25.38/42.00.
Is it just me or are these temps kinda high?
BTW: I used a pea sized drop of thermal and spread a thin layer across the entire CPU with a dry paper towel.
 Post subject: Re: Overheating FX-8350
PostPosted: Wed May 29, 2013 1:16 pm
I think it's a little warm, but I don't know. However the first fault is you spread it with a paper towel. You're supposed to either spread it with a credit card or similar or with your finger in saran wrap. Paper towels aren't exactly "lint free" material.
PostPosted: Wed May 29, 2013 1:19 pm
Yea I thought of that right after I did it :oops:
But would that really bump the temps that high? I want to make this thing a little cooler, so I can run a slight OC
PostPosted: Wed May 29, 2013 1:42 pm
I don't know, but I would reapply the thermal grease.
PostPosted: Wed May 29, 2013 3:11 pm
Million Club - 20 Plus
and get some of 'the good stuff' when you decide to redo the TIM. Why take it apart twice for the same thing.
PostPosted: Thu May 30, 2013 8:52 am
do you really need to spread it? I just put the drop on and attach the heatsink.
PostPosted: Thu May 30, 2013 10:26 am
It doesn't matter, really. But for ease of application, put a drop it, put heastink in, twist slightly back and forth to spread, then secure.
PostPosted: Sun Jun 02, 2013 8:45 pm
I absolutely concur. Reinstall with quality paste and properly apply with credit card. I ordered the good stuff along with my new chip, I'm sure place you got your chip from sells it. Good luck.
