It is currently Thu Jan 29, 2015 2:43 pm
 Post subject: I NEED HELP ON MY SECOND PC BUILD
PostPosted: Thu May 30, 2013 3:34 am
I need advice on my new build i have cash but in short supply. I want my pc to be able to handle 3d applications like 3d's max,maya, and games such as crysis without breaking down i am not into SLI or Crossfire boards. budget around $1000
pc blueprints is as follows
i5 -3570k-cpu
Asrock H61m HVS-mobo
8gb ddr3-ram
i need a 600 series geforce card or a 6000 series radeon card
a good ssd
1tb sata drive -western digital
case coolmaster haf 922
psu is 600w enough.
 Post subject: Re: I NEED HELP ON MY SECOND PC BUILD
PostPosted: Fri May 31, 2013 3:34 pm
not really sure bout the 3d programs but if you get a 3570k you should go with a Z77 chipset MOBO so you can overclock if you ever feel the need to. also 600 watts is more than enough for the system your describing here is a link to pc part picker with a full build and under a grand in price i think it should suit your needs http://pcpartpicker.com/p/11HP8
PostPosted: Fri May 31, 2013 9:18 pm
Thanks for the your input now I have a blueprint for my next pc build.
