It is currently Sun Feb 01, 2015 4:07 am
 Post subject: Are all of corsair's XMS3 Series of RAM sticks the same size
PostPosted: Sat May 25, 2013 10:22 am
Are all of corsair's XMS3 Series of RAM sticks the same size? CMX4GX3M1A1600C9 and CMX8GX3M4A1600C9 is the same Dimensions as model CMX8GX3M2A1333C9. Like is it the same wide, length and height? And which one is bigger XMS2 or XMS3?
 Post subject: Re: Are all of corsair's XMS3 Series of RAM sticks the same
PostPosted: Mon May 27, 2013 12:45 pm
If it looks the same, it probably is the same.
PostPosted: Tue May 28, 2013 4:21 pm
Why are you asking? Trying to fit memory (a critical part) under a cooler that over hangs it (a bling part)? I'd advise to make a wise decision on the memory and then check if the CPU cooler works with it. We're talking mm's here either way. If you are really worried, there's fine low profile memory out there that are just fine.
