It is currently Tue Jan 27, 2015 10:54 pm
 Post subject: Budget Tower ------------------
PostPosted: Tue May 14, 2013 7:43 pm
Getting a new tower, old one is from 1999 /: so pretty much anything is an upgrade!
Have to keep it under $400!
Only thing I really care about is the graphics card. I play a lot of games and want to be able to play on the best or as good as a $400 computer will get me graphics. Been looking at the Dell inspiron 660's. Would also like to get something I could possibly stick a nice graphics card in down the road later that gives me the possibility to do so.
Top 3? What are some suggestions?
 Post subject: Re: Budget Tower ------------------
PostPosted: Tue May 14, 2013 10:32 pm
Anything with an AMD APU. Anything else and you'll have graphics suitable for a 2004 rig. Or you can try to find a used computer.
PostPosted: Wed May 15, 2013 9:04 am
not much at that price range, this would be your best bet
Gateway DX4870-UR348 Core i3-2130 Dual-Core 3.4GHz 4GB 500GB
$325 http://www.geeks.com/details.asp?invtid ... -R&cat=SYS
$330 http://www.microcenter.com/product/4094 ... furbished#
MSI R7770-PMD1GD5 Radeon HD 7770 GHz Edition 1GB
http://www.newegg.com/Product/Product.a ... 6814127687
$85 (w/ 16% promo deal "EMCYTZT3442, ends 5/16 and $20 MIR normally $125)
not bad for $415 at most, plus shipping. The only concern would be, that power supply would probably need a replacement after about a year or so.
PostPosted: Fri Jun 07, 2013 10:43 pm
Go for AMD APU for your graphics card and go for a cheap case and parts that are not being used that much.
value point distribution
