It is currently Fri Jan 30, 2015 3:44 am
 Post subject: Need a good sound bar.
PostPosted: Wed May 01, 2013 10:34 am
Ok so for the longest time i have been rocking a old wallmart vizio soundbar paired with a POLK audio sub purchased on newegg and recommended from you badasses..
The sub dominates and i do not forsee a need to upgrade anytime soon. However my speaker bar is becoming an issue when playing back Blueray movies in a player like Powerdvd
Turns out that my speaker bar does not recognize the codec or something and shuts itself down.
SO this summer sometime i plan to purchase a 200-500 dollar speaker bar that has a sub out for my awesome polk sub
TLDR: I need a great speaker bar that ships without a sub so i can hook the new speaker bar into my awsome sub.
 Post subject: Re: Need a good sound bar.
PostPosted: Wed May 01, 2013 11:28 am
Chances are you should just get a receiver and bookshelf speakers at this point. A lot of sound bars either don't have subwoofer options, use a proprietary connector, or are wireless.
PostPosted: Wed May 01, 2013 8:02 pm
I personally use a Harman Kardon stereo receiver with a pair of Klipsch BA-10B bookshelfs with a powered sub.....this is connected to a PC, makes any and I mean ANY (including the Klipsch ProMedia 2.1) computer speaker/sound bar look foolish and it sounds awesome, sure it requires an analog output from the PC but with a decent sound card (check) decent interconnects (check) it'll rock your world and not require some silly codec impeding sound bar.
PostPosted: Thu May 02, 2013 9:54 am
got any setups you would recommend in the 250 to 300 range?
PostPosted: Sun May 05, 2013 9:24 am
If your not concerned with surround, my first choice and would be within budget, Corsair SP2500 2.1 speaker system, pounds like a mofo and sounds really nice.
The other alternative, would be receiver/speakers/sub but then it does start to get pricey at that point.
Users browsing this forum: Usahamper21 and 12 guests
