It is currently Wed Mar 04, 2015 4:57 pm
 Post subject: Lian Li TR-5 Thermomter problem
PostPosted: Sat Apr 27, 2013 12:26 pm
Ok. I'm in a quandry. I have a Lian Li TR-5 Thermometer. Does anyone know how to install the 4 Thermal Sensors that are for CPU, VGA, SYS 1 & SYS 2? How and where do I connect these? I'm not concerned with the VGA. The sensors aren't plugs. The connectors at the end of the cable are flat. I know you don't tape them. And of course the installation guide doesn't say how & where and the Lian Li website has nothing that explains how & where to connect these. Can anyone help?
I'm running:
Mobo is an MSI FM2-A85X-G65
CPU is an AMD A10-5800K 4M FM2 Black Edition
CPU Cooler is a CoolerMaster Hyper 212 EVO
Thanks
 Post subject: Re: Lian Li TR-5 Thermomter problem
PostPosted: Sat Apr 27, 2013 12:47 pm
http://www.overclock.net/t/1005967/how- ... emp-sensor . Same principle applies to the GPU, if you're willing to take it apart. And the SYS ones are probably for the chipset, which is also the same principle to install.
Though I'm more partial to using something like HW Monitor, since that's probably more accurate.
PostPosted: Sat Apr 27, 2013 11:02 pm
This is (was jodydfw). Thanks for the info. I checked the website you gave and i've decided to go with what you said you're partial to. HW Monitor. Too much tape & BS with the TR-5. Thanks. I really do appreciate it.
PostPosted: Sun Apr 28, 2013 2:54 pm
Thank you so much. I decided to do to what you use. HW monitor.
